TwinTurbo.NET: Nissan 300ZX forum - My OEM, stock length rear studs are 46mm. Source: my caliper
flashstar
on June 06, 2015 at 12:13 AM
sawbonez says 46mm, then they say Bernie says 50mm,
posted by XTZ
on June 05, 2015 at 05:45 PM
Believe me, I've pulled in a bunch in the past. If you go longer, you'll need to cut a hole in the rear cover or pull the hub. Longer studs will not fit in between the rear dust cover and hub.
What is the stock length of the front and rear wheel studs
XTZ
20:09:28 06/04/15
I searched "stock wheel stud length" and the answer came up
Zuberman
16:49:16 06/05/15
XTZ
17:45:14 06/05/15
My OEM, stock length rear studs are 46mm. Source: my caliper -
flashstar
00:13:29 06/06/15
Thank you. (n/m)
XTZ
14:58:03 06/06/15
50mm are NISMO, which is not stock. 46mm is stock. (n/m)
Zuberman
01:27:08 06/06/15
